Liberty, MO – Continental Disc Corporation has launched the new HPX™ and HPX SANITARY rupture discs. The HPX rupture discs are scored reverse acting rupture discs that can be pressurized from full vacuum up to 90% or 95% of the rated (marked) burst pressure under normal operating conditions. These high precision rupture discs offer proven performance in excess of a quarter million cycles.
The HPX and HPX SANITARY rupture discs are differential pressure relief devices that provide an instantaneous full-open, non-reclosing design for protecting equipment, vessels, systems and people from overpressure conditions.
Both rupture discs are also highly versatile and offered in a wide range of burst pressures, materials and sizes. The HPX SANITARY rupture disc is designed specifically for the pharmaceutical, biotech, and food and beverage industries. With a response time in milliseconds, this rupture disc meets all ASME BPE criteria including a surface finish of 20 Ra microinch or better and a solid metal construction providing cleanability for CIP/SIP applications. The HPX SANITARY rupture disc includes sanitary, environmentally friendly, non-toxic packaging.
www.contdisc.com
Filed Under: Factory automation, Automation components, Packaging, Mechanical, Safety systems + components
