Chainflex‚® continuous-flex cables can handle tight bending radii as small as four times the outer cable diameter in dynamic applications and have been tested to validate service life over time.
In the cable construction, the conductors are tightly twisted into groups and then cabled into bundles. The conductor bundles are then cabled around a tension-proof center. Bundling the conductors and eliminating multi-layers ensures a uniform bend radius across each conductor.
igus
www.igus.com
