ContiTech has introduced ContiAlert, a unique conveyor-belt monitoring process that allows users to see belt wear in real time.
“A red bonding layer below the top cover is exposed when it’s time to change the belt,” said Chris Marchant, product manager for conveyor belting.
“In addition, the ContiAlert system is complete with a calculator that enables customers to determine how much time is remaining before the carcass is exposed and the belt is in need of replacement. It takes the guesswork out of belt replacement, and helps prevent downtime and increase uptime.” More after the jump.
“Prior to the introduction of ContiAlert, the end user was only aware that they had maximized their belt life when the carcass became fully exposed,” Marchant said. “The purpose of the covers is to protect the carcass. When the covers are removed and the carcass is exposed to the application/environment, this can negatively impact belt and splice performance. Conti®Alert in real time provides a visual alert that cover wear is approaching exposure of the carcass.”
ContiAlert is available in the abrasion-resistant lineup of ContiTech Select Conveyor-Belt specifications and compounds:
Plylon Plus 250/2, 275/3, 500/4 and 600/3 …
… with a minimum 3/16-inch by 1/16-inch to a maximum of 3/8-inch by 1/8-inch covers.
Abrasion-resistant compounds include Defender Plus, Stacker, Survivor and Survivor Plus products.
For additional information on ContiTech Select products, visit www.contitech.us.
Related feature:
Small to big, conveyors get job-specific features
Today’s conveyors perform better than ever thanks to material advances and modular designs tailored to applications. That’s true of miniature conveyors for discrete product sorting, extra-large conveyors for bulk material-handling operations, and everything in between.
Discrete medical, pharmaceutical and assembly applications use the most miniature conveyors, but until the last decade or so, most such conveyors had frames made in-house. Traditional conveyors also have overdesigned bearings and frames, often to ensure safe operation. But the trend today is toward leaner operations that run right-sized systems. The problem is that customizing right-sized conveyors is sometimes hard because the manufacturer must account for the handling and orientation of parts during movement, as well as the application environment … read more.
