New Contrinex Series 4050 photoelectric sensors with improved background suppression are built into a 40 x 50 x 15 mm housing and offer an operating distance of 500 mm, with a setting range from 20 to 500 mm.
The operating distance is independent of the target color, shape or surface structure, and is set by means of a 3-turn potentiometer with position indication. The devices feature a switching frequency of 500 Hz and work with red light, simplifying their alignment. Their optical characteristics result in a quasi-linear output function with a virtually negligible blind zone (< 1 mm at s = 300 mm).
The sensors are enclosed in a glass-fiber-reinforced PBTP housing, complying with insulation class II. They are equipped with a glass window and a connector that may be adjusted from 0 to 90°. In addition to conventional mounting methods such as mounting brackets, dovetail fastening provides an alternative option.
www.contrinex.com
Filed Under: SENSORS, TEST & MEASUREMENT
