Metal-cutting company Sandvik Coromant is expanding its milling offering with the new CoroMill MF80 for automotive milling applications in ISO K and ISO P materials in close to 90° operations with fixture constraints.
Sandvik Coromant CoroMill MF80 in action.
Based on a technology platform like the existing CoroMill 345, this new milling concept offers a 40% lighter cutter body with shim protection and a high number of inserts for secure and stable machining, even in vibration-prone overhang applications. The 89.5° approach angle enables the multi-edge cutter to work close to the fixture, which not only greatly improves machine utilization, but also ensures a longer tool life with less scrap.
The inserts have eight cutting edges, chip protection, and optimized micro geometry for better security and chip evacuation, as well as a wiper edge for a superior surface finish. The cutting edge is inclined for smooth cutting action and low cutting forces, making it ideal for thin-walled components and machine setups with limited stability.
In a roughing shoulder-milling performance test with a competing brand, the CoroMill MF80 showed a remarkable 67% increase in tool life, which, in turn, boosted overall productivity by 60%. After 40 minutes of machining, the comparison ended with 15 freshly machined components for Sandvik Coromant and nine for the competitor. The shim protection and high number of insert edges effectively lowered the cost per part in this roughing application.
Sandvik Coromant
www.sandvik.coromant.com
You may also like:
Filed Under: Machine tool industry + subtractive manufacturing
