Cost Effective Basic Function
By Design World Staff | August 5, 2009
The IMPACT67 compact field bus I/O modules feature plug-in terminals, diagnostic options and IP67 protection, and are designed to meet the basic demands of all conventional machine installations.  The modules have predefined inputs and outputs, port-related cutoff and single channel diagnostics via LED. The modules are also equipped with field bus group diagnostics to reduce machine outages and ensure that faults are quickly localized and rectified.
They are available with different bus protocols, including Profibus, CanOpen, DeviceNet, EtherCat and EtherNet /IP. The modules also feature pluggable connections and diagnostic options.
Murrelektronik, Inc.
www.murrinc.com
Filed Under: Ethernet — cables • hubs • switches, I/O modules, Networks • connectivity • fieldbuses
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
Avnu Alliance launches global TSN Certification program
Hardened multi-speed mega PoE injector for diverse infrastructure applications
EKI-7000 Series Firmware Revision makes network management more secure
