Cost-Effective Integrated Transceiver Ideal For Industrial Control
By MORNSUN | November 5, 2017
TLAxx-03KCAN & TLAxx-03K485 series are 3 W AC/DC power supplies integrated CAN/485 transceiver and can directly get power from AC 220 V. They’re compact, cost-effective, and ideal for industrial control, grid power, and instrumentation applications.
There are two isolated outputs. The main DC power output up to 2.5 W and the auxiliary one powers bus communication. Isolation voltage is up to 4000 VAC between AC input terminal and two DC output terminals. It is 1500 VDC between the two DC output terminals.
TLAxx-03KCAN & TLAxx-03K485 series use female header with common pins to ensure customers easily achieve automated processing, maintenance, and replacement. The series are protected by patents.
Applications:
Industrial control, grid power, and instrumentation applications with demanding volume, wide input voltage range, isolation bus, and the need to meet UL / CE certification.
Features:
  • Compact size, wide input voltage range: 85-305 VAC/100-430 VDC
  • AC and DC dual-use (input from the same terminal)
  • Isolation voltage: 4000 VAC
  • Protections: SCP, OCP
  • Baud rate up to 1 Mbps (CAN) / 500 kbps (485)
  • Connect up to 110 (CAN) / 128 (485) nodes on one bus
  • Open frame, high power density
  • Flexible peripheral circuit design removing from layout troubles
  • Meet UL60950, EN60950 standards
Part Number
Output Power
Rated Output Voltage (V)
Rated Output Current Io(MA)
Efficiency (230VAC,%/Typ.)
Baud rate (kbps)
Nodes
Certification
TLA03-03KCAN
3W
3.3V(1.65W)/5V(0.125W)
500/25
55
5-1000
110
EN60950
TLA05-03KCAN
3W
5V(2.5W)/5V(0.125W)
500/25
68
5-1000
110
EN60950
TLA03-03K485
3W
500/25
55
500
128
EN60950
TLA05-03K485
3W
5V(2.5W)/5V(0.125W)
500/25
68
500
128
EN60950
