    • On the Floor
Coupling-hose combination handles high pressure
By Frank Tobe | June 10, 2014
Kurt-HydraulicsDesigning for off-highway applications that encounter high hydraulic pressure and a wide temperature range is easier with this line of 6W Couplings. The couplings come with high pressure braided hose for applications that encounter pressures to 6000 psi, and temperature ranges from –40° F to 250° F. These couplings are a one-piece, bite-the-wire crimp coupling with non-skive design to eliminate cover skiving before assembly to the hose.
The couplings make assembly simple, quick and enhance the hydraulic hose assembly to maintain more integrity which is crucial in many applications. The couplings eliminate leaks and in-field failures caused by shock and vibration.
They are available in 85 types and sizes of 1¼ in., 1½ in., 2 in., and work with SAE R13 and 4SH hydraulic hose. They withstand pressure to 6000 psi.
Kurt Hydraulics
www.kurthydraulics.com
Filed Under: Hose • wraps + sleeves, Couplings, MOTION CONTROL
Tagged With: kurthydraulics
    • On the Floor
