Couplings for special environments
By Mike Santora | September 26, 2019
NBK-logo-imageNBK provides couplings that can be used in special environments such as clean room, vacuum, high temperature (80 ° C or higher) are available.
● Low particle
The amount of attached particle is ultra low.
This is directly available in a cleanroom. This does not bring contaminated matters into a cleanroom.
● Vacuum-supported
A material with which outgas production in a vacuum environment is small is used.
If misalignment becomes larger due to vacuum pressure difference,MOHS MOP, for which larger misalignment is permitted, are recommended.
真空対応
● Less outgas
Materials with which production of outgas that causes chemical contamination under atmospheric environment is small are used.
● Heat resistant
This is available even in an environment of high temperature( 80℃ or higher)
Elongation or deflection of a shaft associated with thermal expansion may increase misalignment. If misalignment becomes larger, MOHS MOP, for which larger misalignment is permitted, is recommended.
● Chemical resistant
Materials superior in chemical resistance are used.
NBK
www.nbk1560.com/en/
Filed Under: Coupling Tips
Tagged With: nbk
