Crouzet Introduces the Transportation Limit Switch
By Stacy Combest | April 2, 2013
Crouzet introduces the Transportation Limit Switch. This switch makes installation easy due to its threaded body and compact size and a scaper seal to prevent the plunger from sticking. It is also resistant to harsh environments and low temperatures. The switch is designed to operate on dual-current and medium-current circuits with a mechanical life up to 10 million cycles.
Limit-Switch
Crouzet’s switch is ideal for material handling, transport lifting systems, rail and bus systems and agriculture applications. For more information on the Transportation Limit Switch, click here.
Crouzet
www.crouzet.com
Filed Under: Switches
Tagged With: crouzet
