    • Subscribe!
Crystek Maximizes Performance And Efficiency In Coaxial Resonator Oscillator
By Stacy Combest | April 1, 2013
Crystek’s CVCO55CXT-5685-5780 Coaxial Resonator Oscillator (CRO) is a coaxial-based VCO with an internal proprietary frequency doubler. The CVCO55CXT family’s frequency doubling, 2X fundamental technology reaches new performance levels of lower phase noise and much lower harmonics over the competition, while achieving lower current consumption in the process.
The CVCO55CXT-5685-5780 operates from 5685 to 5780 MHz with a tuning voltage range of 0.3 Vdc to 4.7 Vdc. This coaxial VCO features a typical phase noise of -102 dBc/Hz @ 10KHz offset and has good linearity. The CVCO55CXT-5685-5780 CRO exhibits an output power of 0.0 dBm typ. into a 50 ohm load with a supply of +5.0 Vdc and a current consumption of 25 mA (max.).
CRY-302web
Engineered and manufactured in the USA, the CVCO55CXT-5685-5780 CRO is packaged in the industry-standard 0.5-in x 0.5-in package. Pushing and Pulling are both minimized to 1.5 MHz/V and 0.5 MHz, respectively. Second harmonic suppression is -30 dBc typical.
Crystek Corporation
www.crystek.com
Filed Under: Electronics • electrical
Tagged With: crystek
molex-premo-flex
    • Subscribe!
