Crystek Maximizes Performance With Coaxial Resonator Oscillator
By Stacy Combest | February 28, 2013
Crystek’s CVCO55CXT-5270-5375 Coaxial Resonator Oscillator (CRO) is a coaxial-based VCO with an internal proprietary frequency doubler. The CVCO55CXT family’s frequency doubling, 2X fundamental technology reaches new performance levels of lower phase noise and much lower harmonics over the competition, while achieving lower current consumption in the process.
The CVCO55CXT-5270-5375 operates from 5270 to 5375 MHz with a tuning voltage range of 0.3 Vdc to 4.7 Vdc. This coaxial VCO features a typical phase noise of -102 dBc/Hz @ 10KHz offset and has good linearity. The CVCO55CXT-5270-5375 CRO exhibits an output power of 0.0 dBm typ. into a 50 ohm load with a supply of +5.0 Vdc and a current consumption of 30 mA (max.).
Crystek-Oscillator
Engineered and manufactured in the USA, the CVCO55CXT-5270-5375 CRO is packaged in the industry-standard 0.5-in x 0.5-in package. Pushing and Pulling are both minimized to 1.5 MHz/V and 0.5 MHz, respectively. Second harmonic suppression is -30 dBc typical.
The CVCO55CXT-5270-5375 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
Crystek Corporation
www.crystek.com
Filed Under: Test + measurement • test equipment
Tagged With: crystek
mti
MTI
moog
Going small with 3D printing
