Crystek’s Voltage Controlled Oscillator
By Design World Staff | January 30, 2009
Fort Myers, FL ‚– Crystek’s CVCO55CC-2300-2450 VCO (Voltage Controlled Oscillator) operates from 2300 MHz to 2450 MHz with a control voltage range of 0.5V~4.5V. This VCO features a typical phase noise of -106 dBc/Hz @ 10KHz offset and has excellent linearity. Output power is typically +4 dBm.
The model CVCO55CC-2300-2450 is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 5V, with a max current consumption of 35 mA. Pulling and Pushing are minimized to 0.5 MHz and 1.3 MHz/V, respectively. Second harmonic suppression is
-15 dBc typical.
The CVCO55CC-2300-2450 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
www.crystek.com
Filed Under: Electronics • electrical, Signal analyzers
molex-premo-flex
