Cube Encoders: Updating an Old Industry Favorite
By Mike Santora | March 10, 2022
cube_encoders_news_pagePOSITAL’s line of cube encoders is perfect drop-in replacements for traditional designs. Without special mounts or brackets, installation is simple. Programmability of incremental interfaces and resolutions, as well as a robust housing make these a versatile choice for new and traditional machines. The measurement module inside the cube provides high levels of accuracy and dynamic response in a rugged package that is tolerant of shock and vibration loading, dust, and moisture. Identical mechanical dimensions and interfaces for traditional cube designs also make them a cost-effective replacement for older or unreliable units.
Simple Installation – No Special Mounts or Brackets Needed
Robust Housing Tolerant of Shock and Vibration Loading
Programmability of Incremental Interfaces and Resolution via
UBIFAST Configuration Tool
Cost-Effective Solution for Accurate Positioning
Easy Drop-In Replacement
Posital
www.posital.com
Filed Under: Uncategorized
Tagged With: posital
54879_Network shares according to HMS 2022
Industrial networks keep growing despite challenging times
ABB_e-Configure
Device Data: do-it-yourself is history
AutomationDirect-Fath
FATH T-Slotted rail hardware from AutomationDirect
eSIGN_3
New eSIGN signal tower from WERMA
