    • Subscribe!
Push-button switches target space-constrained applications
By Lee Teschler | September 14, 2021
Available in compact packages as small as 9×6 mm with profiles as low as 5 mm, the MPB series is a family of mini push button switches featuring SPST, SPDT, or DPDT circuit types, off-(on) or on-(on) switch functions, and pitches of 2.54 or 5.08 mm. Thanks to their compact footprints, these mini push button switches are candidates for a variety of space-constrained consumer electronics and industrial control applications.
The push-button models offer surface mount or through-hole mounting styles and terminations including cui devicesstraight, vertical or straight with bracket, and right angle. Additional configuration options include flush, 3.3 mm, or 5.4 mm actuator heights with the 5.4-mm versions featuring actuator cap colors of red, white, or black. The MPB models further carry operating temperature ranges from -25 up to 80°C and a push button life of 20,000 cycles.
CUI Devices’ push button switches are available immediately with prices starting at $2.55 per unit at 500 pieces through distribution. Please contact CUI Devices for OEM pricing.
For helpful resources and tools on switches, check out the Resource Library that houses a range of blog posts, videos, and more.
Availability: Stock to 8 weeks
Possible users: Space-constrained consumer electronics and industrial controls
Primary features: Compact packages, multiple configurations and options
Cost: $2.55 per unit at 500 pieces through distribution
CUI Devices, 6405 SW Rosewood St, Tualatin, OR 97062, (877) 323-3576, www.cuidevices.com
You may also like:
  • electrocaloric cooling
    Keeping cool with capacitors
  • pie in the sky
    Sizing up renewable energy aspirations
  • condo collapse
    Simulation brings insight into the condo collapse
  • how to think
    STEM classes don’t teach engineers how to think
  • R&D blues: Don’t blame educators for flagging innovation
Filed Under: TECHNOLOGIES + PRODUCTS, Switches
Tagged With: cuidevices
Nitra-iso-solenoid-valve-from-automation-direct
ISO 5599/1 pneumatic solenoid valves from AutomationDirect
person's fist holding a handful of igus cables
igus is adding 2,046 new macros to the EPLAN circuit diagram software
Product Image of the NTE2620
Acromag expands its line of ethernet remote I/O modules
Beckhoff’s EPX series EtherCAT I/Os provide intrinsic safety in IP67 form factors
    • Subscribe!
