CUI Expands DC Power Jack Line-Up
By Patrick Curran | April 14, 2011
CUI Inc announced an addition to their Components line which now includes a locking nut dc power jack for panel mount requirements. These rugged dc jacks have a center pin diameter of 2.1 mm or 2.5 mm and an outside diameter of 5.5 mm. Contact resistance is 30 m Ω MAX and insulation resistance is 100 M Ω MIN @ 500 Vdc. The jacks are able to withstand a voltage of 500 Vac R.M.S. for one minute and have a voltage rating of 20 Vdc at 5 A.
CUI-DC-Power-Jack-PJ-06X
Options include long bushings for mounting to thick enclosures, locking nuts with washer, and pins that are designed to solder directly to wire leads or printed circuit boards in vertical and right angle orientations. All power jacks are RoHS compliant. The jacks are available through Digi-Key with prices starting at $0.829 per unit at 1,000 pieces. Please contact CUI for OEM pricing.
CUI Inc
www.cui.com
Filed Under: Electronics • electrical, Fastening + joining • locks • latches • pins, Power supplies
molex-premo-flex
