Custom All Stainless Steel Caster Rolls in Line
By Stacy Combest | July 31, 2013
Stainless Steel Caster WheelWhat began as a simple wheel order spawned into a new Hamilton innovation when our engineering manager, Jeff Spektor, realized a fresh design could save a major aerospace supplier big bucks – and headaches.
When he saw what the customer needed, he knew a standard wheel wouldn’t work. So they came up with a unique design that exceeded the customer’s expectations – an all-stainless steel caster with inline wheels.
Building a Caster to Biohazard Standards
Several factors made this job unique, especially the federal regulations for the room where our casters are used. Everything inside the clean-room environment, including our casters, must adhere to strict standards so nothing damages the sensitive (and top-secret) equipment being tested.
That’s why they chose an ultra durable, high-grade stainless steel (316L) that has superior corrosion and pitting resistance, and performs extremely well under continuous use. 316L contains less carbon than industry-standard 303 or 304 stainless steel and they avoid contamination during the welding process.
Inline Wheels Stay on Track
Unlike a dual-wheel caster that features wheels side by side, this caster, rated up to 15,500 lbs., runs with back-to-back wheels that support each other. It rolls on rails that presented a special set of challenges that we overcame.
For example, when the first wheel goes over a small hump on the tracks, the back wheel stays on the ground to keep the load completely flat. See the illustration below to better understand how they work:
Caster Wheel Figure-1
Hamilton Caster
www.hamiltoncaster.com
Filed Under: LINEAR MOTION, Motion control • motor controls
Tagged With: hamiltoncaster
