Custom Designed MH Series from CIT Relay & Switch
By Patrick Curran | June 8, 2011
The CIT Relay & Switch custom version of the MH Series is now available to all design engineers looking for even more variety in this switch. The MH series has always offered multiple LED color choices including bi-color illumination with and without actuator and is now offered as a black actuator with laser etched ON/OFF symbol. Featuring over-travel and positive detent, the MH series can be customized to fit your requirement.
Specifications:
—  electrical rating of the MH series is 0.4VA max @ 20VAC/VDC max.
—  electrical life is 50,000 cycles with contact resistance of less than 50mW.
—  dielectric strength is 250Vrms and insulation resistance is greater than 100MW.
—  actuation force is 500 ± 100gF with actuator travel of 2.0 ± 0.2mm.
—  operating and storage temperature is -20°C to 70°C.
Materials:
— actuator is polycarbonate with cap and housing of 6/6 nylon, glass filled.
— contacts and terminals are gold plated.
CIT Relay & Switch
www.citrelay.com
Filed Under: Electronics • electrical, Relays, Switches
molex-premo-flex
Going small with 3D printing
