Panel Designer application is a free online tool for creatively designing the exterior surface of HMI panels. Guided by an intuitive interface, it only takes you a few clicks to turn the standard display exterior into an individually designed panel. In addition to choosing a background color, uploading a company logo and assigning individual buttons, different fonts can be selected in any size and color to achieve the desired result. Once completed, the layout design is saved as a PDF file. It is then possible to get a quote from B&R. The Panel Designer can be found at the following address: http://paneldesigner.br-automation.com
B&R Industrial Automation Corp.
www.br-automation.com
Filed Under: Factory automation, Automation components, Electronics • electrical, HMIs • operator interfaces • monitors, Software
