D4SL-N Safety Interlock Switch from Omron
By Editor | November 21, 2012
Omron Automation and Safety introduces D4SL-N Safety Interlock Switches. Available with 4-, 5- or 6-contacts to satisfy varied application needs, the IP67-rated D4SL-N can be mounted in four different directions without needing to rotate the head. Two wiring methods minimize wiring time and make possible one-touch attachment and removal. Easy to view LED indicators allow users to quickly check switch status from any direction. D4SL-N safety switches deliver a minimum of 1 million operations and boast a minimum key holding force of 1300 N to maximize the range of potential applications that can benefit from a tough, compact safety switch.
Omron
D4SL-N switches are available with two types of wiring. Connector-type wiring models feature a connector cable that reduces the potential for mis-wiring, facilitates fast maintenance, and allows easy switch replacement in the event a switch is damaged. Terminal block-type models include a detachable terminal block to significantly increase wiring efficiency.
6-contact versions of the D4SL-N safety switch enable users to independently monitor door open/closed status, as well as solenoid on/off status, from a single switch.
An optional slide key prevents workers from becoming trapped inside the hazardous area, without having to use a padlock.
Omron STI
www.sti.com
Filed Under: Safety systems + components, Switches
Tagged With: Omron STI
unnamed-30
SICK adds microScan3 Pro I/O safety laser scanner
Modular safety gate system from Pilz now includes the PSENmlock handle module
Automation24 adds Schmersal Machine Safety Devices to its online shop
DEM hazardous area and general purpose safety devices
