Damping Grease Sample Kit
By Marisa Martin | June 23, 2016
FacebookTwitterGoogle+LinkedInPinterestShare
A new, expanded Damping Grease Sample Kit is now available from Nye Lubricants, Inc. The kit features medium-viscosity greases from the Fluorocarbon Gel 868 and NyoGel 774 series of products that were designed to control motion and vibration, maintain accurate positioning, smooth operation, and provide touch feedback for a broad array of mechanisms and controls. These greases exhibit stable, water-resistant, shear thinning characteristics over a range of viscosities.
Nye damping greases operate over a wide temperature range, exhibit low oil separation and evaporation, provide lubrication and protection and are compatible with most plastics and elastomers. The NyoGel 774 Series is thickened by silica, and exhibits low color, high clarity, and medium tack. The greases resist displacement from plastic or metal surfaces. Include      ed in this kit is the newly formulated 774H5 designed to fill a viscosity gap in the series. The Fluorocarbon Gel 868 series is composed of opaque, white products formulated with rust inhibitors and PTFE particles, which can improve lubricity.
Nye has over 70 products, based on different material classes, which solve problems and optimize performance in motion control applications. Some of the grease formulations are modifications of the hydrocarbon-based products in this kit, designed to enhance performance under specific conditions. Others include silicone-based and fully fluorinated gels, as well as specialty fluids. In addition, Nye can custom-formulate a product for your application.
Nye Lubricants
www.nyelubricants.com
The post Damping Grease Sample Kit appeared first on Bearing Tips.
Filed Under: Bearing Tips
Tagged With: nyelubricants
SKF filtration system boosts oil lifetime
New high-performance ball bearing from Schaeffler
Vesconite planter bushings
SKF and Amazon Web Services collaborate
