Although hollow-core optical fiber has been available from overseas providers for years, it has been a goal of DARPA to source it in the U.S., for use in military applications. That is why DARPA teamed with DARPA-funded researchers led by Honeywell International Inc. to develop a novel fiber design that uses a hollow, air-filled core. The air-filled core is superior to glass optical fiber, which limits the intensity of light. The DARPA core dramatically improves performance by forcing light to travel through channels of air, instead of the glass around it.
The research is part of DARPA’s ongoing Compact Ultra-Stable Gyro for Absolute Reference (COUGAR) program.
The hollow-core fiber can be used in military applications such as high-precision fiber optic gyroscopes for inertial navigation. The spider-web-like, hollow-core fiber demonstrates:
- Single-spatial-mode: light can take only a single path, enabling higher bandwidth over longer distances;
- Low-loss: light maintains intensity over longer distances;
- Polarization control: the orientation of the light waves is fixed in the fiber, which is necessary for applications such as sensing, interferometry and secure communications.
Hollow-core fiber can also be bent and coiled while guiding light at speeds 30 percent faster than conventional fiber.
“Previous instantiations of hollow-core fiber have shown these high propagation speeds, but they weren’t able to do so in combination with the properties that make it useful for military applications,” said Josh Conway, DARPA program manager. “The real breakthrough with COUGAR fiber is that it can achieve a single-spatial-mode, maintain polarization and provide low loss, all while keeping more than 99 percent of the optical beam in the air.”
DARPA began COUGAR to enhance fiber optic performance for military-grade gyroscopes and to develop a world-class, hollow-core fiber production capability in the United States.
“While we are still working on integrating this new technology into a gyroscope, the fiber itself is revolutionary,” added Conway. “This type of technology may also lend itself to other types of high-power sensors and additional applications where intense optical beams are required. Hollow-core fiber is also naturally radiation hardened, so it may open up fiber applications to space systems.”
DARPA
www.darpa.mil
The post DARPA creates hollow-core optical fiber for military use appeared first on Wire and Cable Tips.
