DC switching solid-state relays offer low power dissipation, high switching frequency
By Miles Budimir | September 11, 2020
CARLO GAVAZZI has launched the RM1D Series, a comprehensive family of dc switching solid state relays. The RM1D Series is designed for applications that demand critical response times, rapid cycling, and high reliability. They’re suitable for use in transportation, off-grid and renewable energy systems that run off batteries, as well as dc heaters, solenoids, valves, fans, and other equipment that requires dc switching. Their low power dissipation output MOSFET creates superior thermal performance that reduces the size or even eliminates the need for a heat sink. The RM1D Series uses direct copper bonding (DCB) and a housing free of any molding mass to increase reliability and performance, making them the ideal solution for packaging, transportation, conveyors, plastics, and other industries and applications.
Features of the RM1D include:
  • Maximum output ratings: 100 A @ 60 Vdc, 50 A @ 200 Vdc, and 10 A @ 500 Vdc
  • Low power dissipation output MOSFET
  • Switching frequency up to 1,000 Hz
  • 4-32 Vdc control voltage range
  • 100 µs maximum response time
  • 3,750 Vrms isolation between input and output
  • Diagnostic LED indicator
  • Integrated overvoltage protection
  • Clip-on IP20 protection cover
  • Self-lifting terminals
  • Agency approvals: UL, CSA, CE certification
relays
The RM1D Series Solid State Relays are the best choice for switching DC loads while increasing reliability, reducing power dissipation, and improving reliability.
For more information, visit www.gavazzionline.com.
You may also like:
  • hvac guide
    Interactive HVAC guide simplifies circuit protection design process
  • The difference between contactors and motor starters (and reduced-voltage starters)
  • Choosing between (or combining) relays and PLCs
  • Solid-state relay characteristics and applications
Filed Under: TECHNOLOGIES + PRODUCTS, Relays
PROSTEP expands cooperation with Siemens Digital Industries Software
DRP - Line
Andantex will introduce a new planetary reducer design concept at IMTS
Custom pneumatic conveyors for unique applications
Advantech-iDAQ-3
Advantech launches iDAQ modular DAQ
