    • Subscribe!
Delta Tuning Wizards include Pressure/Force Control
By Miles Budimir | June 30, 2010
Delta Computer Systems, Inc. announces the addition of a Pressure/Force Tuning Wizard for the RMC70 Series and multi-axis RMC150 motion controllers.
Delta-Tuning-Wizard-plot
Delta’s Tuning Wizard for position is now available for pressure and force axes, including axes that are often challenging to tune manually when required to transition between position and pressure control. The Delta Tuning Wizard calculates tuning gains for you. The wizard first guides you through the process of obtaining plots. Using this plot data, the wizard then develops a mathematical model of your system. Finally, the Wizard’s gain calculator determines the required gain parameters and presents the user with a simple slider bar to choose the desired system performance—from conservative to aggressive.
Go to deltamotion.com for a free download of RMCTools software and firmware for this added feature improvement. Examples of how to use all the Tuning Wizards are available in the Help section of RMCTools and can easily be used with Delta’s built-in motion simulator.
www.deltamotion.com
Filed Under: Fluid power, Hydraulic equipment + components, Motion control • motor controls, Pneumatic equipment + components, Software
Tagged With: deltacomputersystems
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
    • Subscribe!
