By Ben Talan, President, Motion Index Drives
A rotary index table is often the core of an automated manufacturing system. Its performance directly impacts accuracy, uptime, and throughput across the entire production line. Designing a robust rotary indexer requires more than selecting standard components—it demands thoughtful engineering focused on load capacity, precision, durability, and application-specific requirements.
This article outlines the key engineering considerations that define a high-performance rotary index table and explains how design choices influence reliability and service life.
Why Robust Rotary Index Table Design Matters
In automated systems, the rotary index table performs repetitive, high-load, and high-precision motion. Poor design can lead to premature wear, loss of accuracy, or unplanned downtime. A well-engineered rotary indexer, by contrast, delivers:
- Long operational life
- Consistent indexing accuracy
- High load and moment capacity
- Reduced maintenance requirements
- Custom adaptability to harsh or specialized environments
Because the indexer drives the entire process, durability and rigidity are non-negotiable.
Cam Followers: The Foundation of Load Handling
All rotary index tables rely on cam followers to absorb loads during motion, indexing dwell, and emergency stop conditions. The type and construction of these cam followers play a critical role in overall system strength.
Needle Bearing vs. Journal Bearing Cam Followers
The two most common cam follower styles used in rotary indexers are:
Needle Bearing Cam Followers
- Best for continuous, ultra-high-speed indexing
- Suitable for hundreds of indexes per minute
- Lower load capacity for a given diameter
- Higher strength and rigidity
- Typically offer ~50% greater load capacity than needle bearing styles of similar size
- Ideal for most industrial rotary index table applications
The increased strength of journal bearing cam followers comes from thicker roller walls and larger shaft diameters. For most automation systems, journal bearing cam followers provide superior durability and resistance to shock loads.
Materials and Hardening
In standard applications, case-hardened steel rollers and shafts are critical for wear resistance and long service life. In specialized environments—such as clean rooms or non-ferrous applications—alternative materials may be required. These cases typically involve lower loads and carefully engineered trade-offs.
Cam Design: Barrel vs. Globoidal Cams
The cam profile is one of the most important design elements in a rotary index table, directly affecting accuracy, load capacity, and wear.
Globoidal Cams
Globoidal cams are most often used in smaller indexers or extremely high-speed, continuous-motion applications. However, they present several limitations:
- Smaller cam follower pitch diameter
- Reduced load capacity
- Lower indexing accuracy
Globoidal cams are best suited for timing mechanisms or applications where precision positioning is not critical
Barrel Cams
Barrel cam designs provide significant advantages for most industrial indexing applications:
- Larger cam follower pitch diameter
- Higher torque and load capacity
- Improved rigidity and accuracy
- Better shock-load resistance
High-quality barrel cams are hardened (induction or flame hardened) and finish-ground to ensure long life, minimal wear, and repeatable indexing accuracy over millions of cycles.
Drive System Design: External Reducers and Motors
Using an external reducer coupled with an AC, DC, or servo motor offers major performance and efficiency benefits:
- Precise ratio selection to match speed and torque requirements
- Ability to size the motor correctly without oversizing
- Reduced energy consumption
- Smaller, more compact indexer housing
By moving gearing outside the indexer housing, internal space can be optimized for the cam and cam followers—the components that most directly affect accuracy and durability.
Bearing Systems and Top Dial Rigidity
The rotating dial must support axial loads, radial loads, and tilting moments caused by offset part loading.
Four-Point Contact Bearings
A low-friction four-point contact bearing system provides:
- High axial load capacity
- Strong resistance to tilting moments
- Increased rigidity across the full dial diameter
Some designs rely on very thin axial and radial bearings with gravity-based preload. While compact, these systems limit moment capacity and reduce rigidity at the outer diameter of the dial—where stiffness is most critical.
A robust bearing system ensures consistent positioning accuracy and long-term structural integrity.
Custom Engineering for Application-Specific Needs
No two automation applications are identical. A truly robust rotary index table must be engineered to match:
- Load weight and distribution
- Indexing speed and duty cycle
- Environmental conditions
- Accuracy and repeatability requirements
- Integration with upstream and downstream equipment
Custom engineering ensures the rotary indexer performs reliably for years, even in demanding industrial environments.
Conclusion
Designing a robust rotary index table requires careful attention to cam followers, cam design, bearing systems, drive architecture, and application-specific demands. When engineered correctly, a rotary indexer delivers long life, high precision, and dependable performance—making it a critical asset in any automated manufacturing system.
A well-designed rotary index table is not just a component; it is the foundation of automation success.
Sponsored content by Motion Index Drives
Filed Under: Motion Index Drives Sponsored Content
