DESTACO adds to its heavy-duty manual clamp line
By Michelle Froese | April 7, 2022
The new 503-MLBR and 533-LBR models feature patented Toggle Lock Plus system.
DESTACO, which offers an extensive selection of automation, engineered solutions, and work-holding solutions, has added two new models to its heavy-duty manual clamp product line.
The 503-MLBR and 533-LBR models are extensions of DESTACO’s 503-MLB and 533-LB vertical toggle-lock clamps — with the new versions featuring the patented Toggle Lock Plus locking system.
“The space-saving Toggle Lock Plus latch uses a locking disc to secure the position,” said Nina Wolleb, application engineering manager with DESTACO. “This solution saves space and, since no welding is required, is easy to implement. That provides additional safety and protection against unintentional opening and closing.”
The user-friendly new models allow for fast handling and enable their users to build up applications more efficiently with little interference contour.
The 503-MLBR and 533-LBR clamps are fully interchangeable with models having the same specifications, other models are available upon request.
Filed Under: Clamps • locks • latches
Tagged With: destaco
