Detect All Metals at Same Distance Without Adjustments
By Randy Frank | August 20, 2012
Pepperl+Fuchs NRB/NRN series inductive proximity sensors detect all metals at the same operating distance. Adjusting an air-core coil system ensures that target detection is independent of the metal characteristics. This provides large operating distances and makes the sensors insensitive to interference from frequency converters or strong magnetic fields created in welding operations.
The sensors are available in two form factors. Cylindrical sensor models are offered in diameters from 6.5 mm to 30 mm with operating distances of 1.5 mm up to 25 mm.  Cube-style sensors are available with dimensions of 40 mm x 40 mm or 80 mm x 80 mm with operating distances ranging from 15 mm to 50 mm.
For more information about Pepperl+Fuchs NRB/NRN series inductive proximity sensors, click here.
Sensor Tips
Filed Under: Sensor Tips
Compact direct drive actuator boasts 1.25μm resolution
TMR magnetic sensors optimized for current, position sensing
Tiny dual-port pressure sensor simplifies design of PAP devices
AI/ML-based sensor fusion technology platform targets home-security alarm system
