Sensirion has recently launched two versions of its differential pressure sensors within the SDP600 series. The sensors SDP6x0-125Pa and SDP6x0-25Pa feature particularly low measurement ranges of -125 to +125 Pa and -25 to +25 Pa, respectively. Due to their better resolution, the products have improved zero point accuracy of 0.1 Pa. In addition, zero point repeatability reaches a remarkable 0.05 Pa for the 125Pa version and 0.03 Pa for the 25Pa version. The differential pressure sensors are excellent solutions for many applications in medical and HVAC markets where high accuracy measurements of particularly low differential pressure are required.
The two versions complement the comprehensive product range of Sensirion’s digital differential pressure sensors in the SDP600 series. Along with the other products of this series, they offer a digital I2C output and are fully calibrated and temperature compensated. Thanks to the principle of calorimetric flow measurement, the CMOSens® differential pressure sensors achieve outstanding sensitivity and accuracy, especially around the zero point. Furthermore, the sensors exhibit very high long-term stability and freedom from zero-point drift.
Sensirion
www.sensirion.com
Filed Under: Sensors (pressure), SENSORS, TEST & MEASUREMENT
