Direct Wire’s large gauge MTW cable available from AutomationDirect
By Mary Gannon | May 11, 2021
AutomationDirect’s new 1kV ALL-FLEX MTW/THHW heavy-duty flexible power cable from Direct Wire is an extremely flexible large gauge (8AWG to 500MCM) single-conductor industrial cable that is ideal for industrial control panel distribution, VFD power feeds, servo systems, and motor leads in non-drive related applications.
direct-wire-large-gauge-mtw-wire-5x7The MTW and THHW ratings make them ideal for use in both wet and dry locations and in conduits, ducts, troughs, and control panels.
This cable is also ideal for marine board, uninterruptable power supplies (UPS), transformer wiring, battery chargers, and other non-traditional industrial applications.
ALL-FLEX cable can be ordered cut to length in 1-foot increments with a 20ft (smaller gauges) or 10ft. (larger gauges) minimum, starts at $0.54 per foot and is made in the USA.
AutomationDirect
www.automationdirect.com/large-gauge-mtw
Tagged With: automationdirect
The electrical connection specialists take steps to become a system provider
New edition of IEC 61918 regulates SPE cabling and installation for the automation world
PVC armored BNC and TNC cable assemblies are sealed to IP67
Cut-to-length Quabbin commercial Ethernet and data cables from AutomationDirect
