Displacement detection of hydraulic diving platforms
By Mike Santora | August 3, 2020
PR478_wireSENSOR_P115_A337_hydraulische-Sprungtuerme_Presse_18x131In the water sports center in Leipzig, athletes and future Olympic athletes train in water diving. To achieve optimal training results, height-adjustable diving platforms are used. These enable the athletes to jump from individual heights. The system also has considerable advantages for synchronized divers because the towers can be moved to the same height. Draw-wire sensors from Micro-Epsilon ensure that the towers are always in the exact position.
A console on the edge of the pool easily controls the height between 0.8 and 3.5 m using. A wireSENSOR WDS-P115 draw-wire sensor is used on the diving platform, which detects the retraction and extension of the ladder. The current height of the diving tower is determined using these measured values. The part of the extendable ladder that is not required protrudes into a room below the swimming pool. The draw-wire sensor is attached to the ceiling of the room for this measurement task. The end of the wire is attached to a cross strut of the ladder construction. If the tower is moved, the ladder and the strut move with the rope.
The challenge lies in the high humidity, chlorine-containing environment, and the high number of work cycles that the sensors must perform. Therefore, the WDS-P115 industrial draw-wire sensor from Micro-Epsilon was chosen. Due to their large measuring range, the robust aluminum profile housing, and durable design with wear-free encoders, these modern industrial sensors deliver precise results even in demanding environments. They are also easy to install.
In addition to the standard models, special versions with coated housings and rustproof stainless-steel elements are available for extreme environmental conditions such as saltwater. Additional drain holes allow water to drain off quickly. Deflection pulleys and wire extensions allow flexible adaptation to the respective installation situation.
Micro-Epsilon
www.micro-epsilon.com
Filed Under: Sensor Tips
Tagged With: Micro-Epsilon
Compact direct drive actuator boasts 1.25μm resolution
TMR magnetic sensors optimized for current, position sensing
Tiny dual-port pressure sensor simplifies design of PAP devices
AI/ML-based sensor fusion technology platform targets home-security alarm system
