Diverse Demands of Food Processing
By Design World Staff | April 15, 2010
Food processing has diverse demands, from simple clamping applications, to controlled closed loop bottle filling, to diverters for agricultural product sorting, to heavy duty cylinders used with intensified pressures and in high temperature environments.  Bimba’s products provide solutions that meet FDA requirements, improve efficiency, and reduce costs.
If you’ve got an engineering challenge, Bimba has the solution. Whether it’s a standard off-the-shelf cylinder or a cutting-edge custom assembly, Bimba is uniquely positioned to help you take control of any motion control application. In addition to its broad line of standard catalog products, Bimba also develops many custom and semi-custom products designed for specific customers and applications.
When you work with Bimba, customer commitment comes standard. Bimba is uniquely positioned to provide fast, on-time delivery. What’s more, state-of-the-art stocking software with real-time ship dates enables you to manage your supply chain more efficiently.
Air Preparation Equipment
Dirty, under-lubricated shop air with inconsistent pressure can lead to inefficiency, corrosion and eventual failure of pneumatic components. That’s why Bimba offers a full line of Air Preparation Filters, Regulators and Lubricators (FRLs), including custom assemblies and optional accessories.
Valves
From solenoid air valves to button valves, Mead Fluid Dynamics has the technology to handle the most demanding pneumatic control applications. An innovative approach to design allows these corrosion-resistant valves to perform even in tough wash-down environments, while still yielding smooth speed and control.
Bimba
www.bimba.com
Filed Under: Factory automation, Packaging, Filters (mechanical) for air + fans, Fluid power, Valves
Solid-state relay characteristics and applications
