When Rogers Corporation exhibits at the 2022 IMS in Denver beginning June 21, it will be showcasing its most recently released products in Booth #2030 including Radix 3D Printable Dielectrics and RO4835IND LoPro Laminates.
Radix 3D Printable Dielectric is a 3D material featuring a dielectric constant of 2.8 and low loss characteristics at microwave frequencies. These printable dielectric materials give radio frequency (RF) designers design freedom in creating new components, eliminating the need to consider typical manufacturing design constraints.
This proprietary composite material is designed for Digital Light Processing (DLP) 3D printing, enabling a scalable, high-resolution printing process for end-use RF dielectric component manufacturing. This printable dielectric material has a targeted dielectric constant of 2.8 and a dissipation factor of 0.0043 at 10 GHz when cured.
The material is intended for use as RF material in applications where geometric freedom can enhance the figure of merits of an RF system, such as gradient dielectric constant (GRIN) structures and other complex three-dimensional parts. The Radix 3D Printable Dielectric offers the industry a way to manufacture systems and components at scale that could not be made with traditional fabrication methods. Radix materials are available directly from Rogers Corporation and our 3D printing partners.
RO4835IND LoPro thermoset laminates are designed for 60-81 GHz short-range industrial radar applications where excellent electrical performance and cost-efficiency are equally important. These laminates also provide environmental reliability and interconnection stability, which are critical criteria for PCB material selection.
With a low insertion loss of 2.13 dB/inch at 60 GHz, these laminates meet customers’ critical radar coverage requirements. The expanded weave fiber provides excellent Dk uniformity, and Rogers’ tight quality control provides low Dk variation from lot to lot. RO4835IND LoPro laminates are compatible with standard epoxy/glass (FR-4) processes and have a higher fabrication yield rate compared to conventional PTFE-based laminates. Low material and fabrication costs make RO4835IND LoPro laminates a cost-effective solution for industrial radar.
Rogers Corporation
www.rogerscorp.com
Filed Under: Make Parts Fast
