Mill-Max Manufacturing Corp. Inc. announces the release of double row pre -wired connectors in both spring-loaded and target versions. These products combine high quality Mill-Max pins with the convenience of an 8” pig-tail to suit a wide variety of applications.
The new double row connectors, 889 -22-0XX-70-501010 (spring -loaded) and 889-10-0XX-70-502010 (target), complement the existing single row pre -wired products, offering a greater number of wiring options in a convenient package. For applications where crimped wire
connections are specified, this cost-effective solution eliminates the process of crimping wires to assembled connectors and can replace the time-consuming and labor-intensive crimp and poke style connectors. Both the spring-loaded and target connectors are available in 4-20 positions and are ready to use in a host of wire termination applications. The open -end wire offers flexible termination possibilities such as soldering, crimping, splicing, or connecting to a terminal block.
The spring-loaded 889 series use high reliability Mill-Max spring-loaded pins making it an excellent choice for battery charging, low-power delivery and quick connect purposes.
Both connectors feature precision-machined and gold-plated pins on 0.100 in. (2.54 mm) centers with connector housings molded from high temperature thermoplastic. The spring-loaded pins have a maximum stroke of 0.055 in. (1.4 mm) while the target connector has a burr free mating surface. The 8 in. (203 mm) long wires are 24 AWG stranded conductors per UL1007 with black PVC insulation and 7/32 stranding. There is a positive stop inside the connector so the pins cannot be dislodged if pull force is applied to the wires. The wire crimping is achieved using an 8-point crimp tool per M22520/1-01, insuring the proper tensile retention is attained.
www.mill-max.com
Filed Under: Connector Tips
