    • Subscribe!
Dow Corning and IBM Scientists Develop New Materials for Board-Level Photonics
By Stacy Combest | February 20, 2013
At the Photonics West conference, Dow Corning and IBM scientists unveiled a major step in photonics, using a new type of polymer material to transmit light instead of electrical signals within supercomputers and data centers. This new silicone-based material offers better physical properties, including robustness and flexibility, making it ideal for applications in Big Data and for the development of future exascale computers, which are capable of performing a billion billion computations per second.
With exabytes of structured and unstructured data growing annually at 60 percent, scientists have been researching a range of technological advancements to drastically reduce the energy required to move all that data from the processor to the printed circuit board within a computer. Optical interconnect technology offers bandwidth and power efficiency advantages compared to established electrical signaling.
Screen-Shot-2013-02-20-at-12.54
In a collaboration with Dow Corning, the scientists for the first time fabricated thin sheets of optical waveguide that show no curling and can bend to a 1 mm radius and is stable at extreme operating conditions including 85percent humidity and 85°C. This new polymer, based on silicone materials, offers an optimized combination of properties for integration in established electrical printed circuit board technology. In addition, the material can be fabricated into waveguides using conventional manufacturing techniques available today.
A presentation (entitled Stable and Easily Processable Optical Silicones for Low-Loss Polymer Waveguides) given here by Brandon Swatowski, application engineer for Dow Corning Electronics Solutions, reported that fabrication of full waveguide builds can be completed in less than 45 minutes, and enable a high degree of process flexibility. Silicone polymer material, which is dispensed as a liquid, processes more quickly than competitive waveguide materials such as glass and does not require a controlled atmosphere chamber.
Screen-Shot-2013-02-20-at-12.53
Swatowski’s presentation went on to say that waveguide builds based on the silicone polymer showed excellent adhesion to polyimide substrates. It also discussed how optical characterization of the new polymer waveguides silicones showed losses as low as 0.03 dB/cm, with environmental stability extending past 2,000 hours exposure to high humidity and temperature, and good performance sustained over 500 thermal cycles between -40°C and 120°C.
Dow Corning
dowcorning.com
Filed Under: Electronics • electrical, Lights • signal lamps • indicators, Materials • advanced
Tagged With: dowcorning
molex-premo-flex
    • Subscribe!
