Dremel is offering a new Electric Screwdriver as part of its Home Solutions Products for those everyday building projects. The new screwdriver features a 4V MAX rechargeable lithium-ion battery and a USB port for convenient charging.
The Dremel Electric Screwdriver Kit comes complete with a seven-piece HEX bit set to drive the most common screws and a bit extender.
The screwdriver’s compact size and slim design (at 7″ long) lets users work in tight spaces and at awkward angles, providing additional reach with the inclusion of a bit extender. At 4 volts, the tool’s surprisingly strong and packed with power to drive screws two times faster than similar competitive products in the market.
“With our electric screwdriver you have the most control you will ever experience in a cordless screwdriver and stripped screw heads, over-driven fasteners and damages faceplates are a thing of the past,” says Fulvio Camarotto, Dremel group product manager.
The Dremel Electric Screwdriver provides more control for screw-driving task with its unique six-position clutch. This feature lets a user set the proper amount of torque necessary based on application. It also it has Smart Stop Technology, which recognizes when the driver bit is not fully seated in the screw head and cuts off power, reducing damage to the screw head and removing user error.
Additionally, the Dremel Electric Screwdriver Kit comes complete with a seven-piece HEX bit set to drive the most common screws and a bit extender.
A new Dremel Flashlight also comes complete with a USB cable and power adapter. With 5000K LED lights, the flashlight provides clean, white light for superior visibility, making it ideal for home inspections and repairs. The beam focus function lets users direct light from narrow to wide, between spot and flood with a simple twist. In high-spot mode, the beam extends to a length of 650 feet — the length of two football fields.
The new new line of tools will be sold exclusively at The Home Depot.
