In addition to controlling stepper motors, a variation of4also offers support for servomotors. This drive lets you integrate different drive types. The flexible drive architecture enables easy changeover from a stepper motor to a servo version and vice versa. Despite the small dimensions, the drive supports up to two axes with performance levels of 500 W each on one module. It requires a base surface of less than 50 cm² per axis. Nominal voltage range is from 18 Vdc to 80 Vdc for low power applications.
B&R Industrial Auotmation Corp.
www.br-automation.com
Filed Under: Factory automation, Drives (servo) + amplifiers, Drives (stepper) + amplifiers, Motion control • motor controls, Motors • servo, Motors • stepper
