DTI Series Digital Tilt Indicators from Sherborne Sensors
By Patrick Curran | December 30, 2009
Sherborne Sensors launches the DTI series, a family of 5-digit, programmable digital panel meters, offering improved tilt measurement system versatility and performance.
The DTI series is designed to take an output from any Sherborne Sensors gravity referenced inclinometer, provide the necessary trigonometric conversions, and display the output as an angle, with a resolution down to 0.001°. For seamless interface with a data acquisition system, two supplementary outputs, an analog voltage output and a RS422/485 serial output, are supplied. The enclosure is manufactured from recyclable and flame retardant (VO) materials, with front panel conformance to IP65: NEMA 4.
Because of its versatility, the DTI Series can be effectively implemented into simple, measurement-only applications, as well as those requiring digital communications, alarms and mathematical functions. The powerful menu-driven software, also supplied, enables fast and flexible set-up from the front panel or via serial communications link. In addition, built-in, comprehensive alarm functions for the DTI Series makes them particularly suitable for monitoring, switching and control functions. The hysteresis facility prevents noisy signals from switching alarms erroneously, with high and low deviations facilitating control around a set point. On and off delay times can be set with individual alarms, configured as latching or non-latching, depending on user requirements.
The DTI Series is suitable for use with most Sherborne Sensors gravity-referenced inclinometers, as well as other manufacturers’ products. An integral 12 VDC power supply is intended to provide excitation voltage for MEMS- based inclinometers. Bi-polar voltage supplied inclinometers may be also powered via Sherborne Sensors XT-0102 or XT-0103 series power supply modules. For customer convenience, the DTI Series can also be supplied as a completely calibrated tilt monitoring system, including the inclinometer.
Sherborne Sensors
www.sherbornesensors.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
