    • On the Floor
Dual Output Drawworks Encoder
By Design World Staff | February 22, 2008
BEI Industrial Encoders introduces the new dual output drawworks HS35 encoder for oil field applications. The dual output drawworks encoder can supply simultaneous position feedback to two separate systems from a single encoder. The encoder features a hard-anodized metal housing, sealed connector, IS rating, dual bearings and shaft seals for NEMA 4 and 13 (IP65) ratings.
The dual output drawworks HS35 encoder can supply simultaneous position feedback to two separate systems from a single encoder. Since the connectors are mechanically parallel and electrically isolated, connecting to a second system and routing the cable is straightforward. Additionally, the outputs can even have different resolutions with use of interpolation. Now you can save the cost and space of a second encoder with a single installation.
www.beiied.com
Filed Under: Encoders (rotary) + resolvers, ELECTRONICS • ELECTRICAL
  • Toyota goes all-in on humanoid robots
  • Mobile robotics moves to the textile industry
  • Finally, hard data on humanoid robot cost in the factory
    • On the Floor
