Dual-Port Ethernet Controller
By Design World Staff | September 2, 2008
GERMANTOWN, WI ‚– Integrated Ethernet switch functionality enables WAGO‚’s new 750-871 ETHERNET TCP/IP 2-Port Programmable Fieldbus Controller to optimize networking capabilities while streamlining associated costs. The 750-871 is easily integrated into existing Ethernet networks while minimizing the overall number of components. The controller can link the WAGO-I/O-SYSTEM to the ETHERNET fieldbus and the dual RJ-45 Fieldbus ports daisychain up to 20 devices ‚— each segment may be up to 100m long ‚— within one series.
The controller is programmable in accordance with IEC 61131-3 and also features an integrated DIP switch that may be used for IP address assignment.
Well-Networked Controller:
The 750-871‚’s compatibility with several protocols makes it an ideal system addition. For instance, the 750-871 can utilize MODBUS/TCP and EtherNet/IP for data acquisition or control, and may utilize one of several protocols (HTTP, BootP, DHCP, DNS, SNTP, FTP, SNMP and SMTP) for system management and diagnostics. The 750-871 permits data transmission rates of 10/100 Mbits/s, contains 512 KB of program memory, 256 KB of data memory and 24 KB retentive memory. A battery-backed, real-time clock and 32-bit multi-tasking CPU provide additional reliability and support for a wide variety of applications. HTML pages can be conveniently placed on the 750-871‚’s internal server for use in Web-based applications.
www.wago.us
Filed Under: CONNECTIVITY • fieldbuses • networks • gateways, ELECTRONICS • ELECTRICAL, PLCs + PACs
