Douglas Electrical Components, Inc. now offers Ductorseal® sealed wire and cable assemblies to solve through-bulkhead conductor sealing problems in small engine fuel delivery modules. Ductorseal feedthroughs provide an interconnecting harness in a fully sealed, pre-wired, pre-tested and ready-to-install hermetic unit.
Ductorseal feedthroughs for small engine in-tank fuel delivery module applications feature a precision-machined, chemical-resistant epoxy housing with no mold parting line that can compromise O-rings and cause potential leak paths. They are available in a wide range of standard housing sizes and configurations, and with any number and type of conductors. Aluminum, titanium, steel, brass, and plastic housings are also available. Like all Ductorseal feedthroughs, the units are epoxy-sealed to provide leak-free performance. Connector configurations on both atmospheric and vacuum/pressure sides can be mixed and matched as needed.
DECo designs and manufactures feedthroughs, sealed cables, hermetic seals, sealed connectors, fiber optic seals, bulkhead connectors, coaxial connectors, ceramic feedthroughs, hermetically sealed connectors, electrical feedthroughs, vacuum feedthroughs and waterproof connectors. DECo can hermetically seal any conductor, including wires, cables, harnesses and fiber optics, through any housing, and to any leak rate and sealing level standard, including IP, NEMA and Military MTD-STD-810.
Using customer-furnished or sourced materials, the company also supplies pre-tested, documented and ready-to-install subassemblies, including transducers, sensors, switches, heaters, connectors, flex circuits, ribbon cables, thermocouples, fiber optics and other discreet components.
Filed Under: Cables + cable management, Seals • gaskets • O rings, Connectors (electrical) • crimp technologies, ELECTRONICS • ELECTRICAL
