The Model 80199701 gear motor from Crouzet has a protection index rating of IP20 that can be upgraded to IP54.
The second generation 150 W brushless DC motor from Crouzet (Vista, CA) has a 3-stage plenary gearbox that is durable enough to withstand high loads without operation interruption. Other features of the Model 80199701 gear motor include:
Thousands of hours of life without service.
Variable speeds and torques, with an expanded output from 25 Nm up to 120 Nm.
The ability to hand high side loads with 1,000 M radial and 200 N axial.
A protection index rating of IP20 that can be upgraded to IP54.
An 81 mm diameter and 229 mm length.
An extension on the rear of the motor, allowing for encoder or brake.
Operation with voltages from 6 to 75 VDC.
1-, 2-, or 3-stage gearboxes.
Hall sensors and an industry-standard 8-wire connection scheme.
Uses for applications in the medial, commercial, and industrial markets.
For more information visit www.crouzet.com.
Filed Under: Gears • gearheads • speed reducers, Rapid prototyping
