Available as standard gaskets, custom designs or sheet stock, durable 2700 Series Conductive Foam has X, Y and Z axis conductivity for maximum EMI shielding attenuation. The material is ideal for computer, router and telecom I/O shielding. It is offered with or without pressure sensitive conductive adhesive covering the entire mounting surface or with nonconductive adhesive tape in spot application. Constructed from conductive open-cell polyurethane foam, it has nickel over copper-plated polyester fabric on two sides. The fabric is woven on one side and not woven on the other. Standard thicknesses .059”, .087”, and .134” support up to 50% compression deflection. Conductive Foam is both 94 V-Rated and RoHS compliant, and due to its low compression set it has a long life. Free samples of 2700 Series Conductive Foam are available at www.tech-etch.com/shield/shieldlit.html.
A global leader in shielding technology, Tech-Etch, Inc. manufactures a complete line of standard and custom shielding products for both the commercial and military markets.
Visit the web site at www.tech-etch.com/shield.
