Durex Industries recently announced the product introduction of the SENTINEL® Molded Foam Silicone Rubber Heater. In semiconductor equipment applications Durex Industries’ SENTINEL heaters offer the advances of improved thermal efficiency, higher process temperatures, and reduced system cost.
Durex Industries developed this patent-pending advanced heater technology, because Semiconductor Equipment Industry engineers need thermal solutions that meet specifications for next generation manufacturing processes while reducing thermal system costs. SENTINEL Pump Line Heaters are available in standard I.D. size diameters of 1.0, 1.5, 2.0, 4.0 and 6.0 inch straight sections, elbows, tees, reducers, and flanges. The heaters can
also be easily designed to the dimensions of valves, regulators, and other
gas delivery and pump line components.
SENTINEL heaters are also available using structured silicone rubber heater and extruded silicone insulation technology. Structured heater technology is used in many small 1⁄4 to 3⁄4 inch diameter gas delivery line applications and complex low volume applications.
Durex Industries
www.durexindustries.com
Filed Under: Gears • gearheads • speed reducers, Heaters (electric)
