EAO Corporation has developed a new, flush-mounted buzzer for use in a range of applications with machinery, panel building, medical equipment, lifting and moving, and more.
The modern, flush-mounting design of the Series 61 buzzer installs into an industry standard 22.5mm cut-out and is styled to match the appearance of other EAO control panel components, particularly the Series 51, Series 61, Series 71 and Series 84. By mixing and matching from EAO’s wide range of HMI devices, designers can now build smart contemporary control panels that allow operators a consistent, uniform and intuitive experience.
The Series 61 buzzer delivers a continuous, 88 dB(A) audible warning sound, that is considered to be suitable for mostsignaling requirements. Built from rugged Polyetherimide and protected to IP40, the buzzer matches EAO’s high standards for design, functionality and high-quality material selection.
With a low current consumption, a wide operating temperature range from 25 °C to +55 °C, and simple plug-in connectors, this product is ideal for a wide range of industrial signaling uses. CE and RoHS approved.
EAO Corporation
www.eao.com
Filed Under: Machine tools + subtractive manufacturing, Medical-device manufacture, Displays • HMIs • operator interfaces • monitors, MORE INDUSTRIES, MOTION CONTROL
