By Chris Di Biase
More and more manufacturers are seeing the measurable benefits that a virtual infrastructure can bring to their production environment and making the leap. Despite the increasing popularity of virtualization, many manufacturers are hesitant to make the transition, often feeling they don’t have the proper IT capability to do so effectively.
The good news is that introducing virtualization doesn’t have to be a headache-inducing affair implemented by dedicated IT resources and expertise. Considering current and future system requirements, working with a trusted third-party to design and implement a right-size system can make the transition faster and easier.
Why Virtualize?
The advantages of virtualization are numerous. For one, it enables a facility to run multiple applications and operating systems from a single server versus the traditional one-to-one approach. Greater server utilization and consolidation can free up floor space, while bringing down maintenance and energy costs.
Virtualization finally breaks the invisible chain between hardware and software. Traditionally, upgrading IT-based plant hardware like PC-based Human-Machine Interfaces (HMIs) required that manufacturers also upgrade their software, often prematurely. By decoupling hardware from software, virtualization allows manufacturers to create separate upgrade cycles, extending the useful life of their software systems. As a result, plant managers are empowered to make application upgrades based on business needs, instead of being beholden to the hardware.
On top of all of this, virtualized infrastructures can self-heal. If one physical server goes down, for example, the virtual system can automatically restart the lost applications on other physical servers to quickly get production running again or even prevent it from stopping. Hardware failures no longer need to be major production-halting events.
Design Considerations
From a hardware standpoint, a virtualized infrastructure in a manufacturing environment typically requires two to four physical servers with sufficient RAM to host all of the virtual machines, enough disks to run a plant’s applications at the required speed, and switches and cabling.
The process of changing to a virtualized system should begin with an audit to assess design specifications and business objectives, and then to identify the functional and informational requirements for the virtualized infrastructure. Some questions that will need to be addressed at this stage include:
• How much RAM, CPU and disk I/O do your applications require?
• How many client workstations will be deployed in the virtual environment?
• How many servers will be needed?
• What kind of network switching will be used?
And while understanding how a virtualized infrastructure will support current operations is an obvious immediate need, it’s also critical to be thinking ahead in order to anticipate future needs. Don’t short change what operations might be doing in the next five years. Systems grow and evolve over time, and designing room for growth into a virtualized infrastructure will allow for greater agility, making it easier to deploy new applications down the road.
Pre-engineered, bundled offerings, such as the Industrial Data Center from Rockwell Automation, provide a cost-effective gateway to virtualization for improved uptime reliability and simplified support.
To Build or to Bundle?
When procuring hardware for a virtualized infrastructure, there are two options. The first is to build the infrastructure from scratch, which requires ordering all of the necessary equipment, assembling it and commissioning it. This can be a burdensome and time-consuming approach: equipment must be ordered from multiple vendors and system design, fabrication and testing can take weeks. There also are added costs of hiring certified installation professionals or trained technicians to provide support.
The alternative to this approach is a bundled solution. Bundled offerings are preassembled systems that include all of the hardware, software and documentation for a virtualized system in one turnkey solution. These solutions are assembled using industry best practices in areas like cable management, system grounding and labeling and have been pre-engineered so that the infrastructure design effectively addresses all system needs.
Bundled offerings typically include implementation services to execute the on-site network configuration and integration. From design to deployment, a virtualized system can be up-and-running in a matter of days for a bundled solution versus a matter of weeks for a non-bundled solution.
When going the bundled route, it’s crucial to understand that not all solutions are designed to exclusively address the unique characteristics of a manufacturing environment. This is an important consideration to keep in mind, because different industries have different priorities when it comes to downtime, system complexity and cost.
A five-minute system crash in a corporate office environment, for example, could lead to the temporary loss of email and business systems; an inconvenient and perhaps even costly event. A five-minute server crash in the manufacturing environment, however, can lead to a catastrophic downtime event, such as the loss of a high-value batch.
Similarly, some bundled solutions that are designed for environments, such as corporate data centers, could include features that are in excess of or not relevant to the needs of a manufacturer, which can drive up costs. Consider whether the solution you choose is purpose-built and purpose-priced to meet your unique needs.
Simplify Your Support
One of the appeals of a virtualized infrastructure versus traditional client-server architecture is the simplification of ongoing management. A virtualized system makes it possible to control and manage operator and engineering workstations from a central location. But as with anything in a production facility, the systems do still require servicing and support for maintenance, repairs and upgrades.
Selecting a solution provider that offers technical support with their product can make life easier for the maintenance manager; they’ll have one phone number to call for whatever questions or support issues arise across the system’s lifecycle.
Also consider what additional levels of support may elevate the organization’s performance given new capabilities enabled by virtualization. A virtualized environment simplifies remote monitoring, for example, allowing a provider to monitor the complete virtualized infrastructure, identify and troubleshoot issues, or contact maintenance personnel immediately to alert them of a problem – all from an off-site location. This is particularly important for manufacturers that don’t have an IT administrator in their plants or lack the expertise needed to maintain and service the virtual infrastructure.
Rockwell Automation
www.rockwell.com
Filed Under: Displays • HMIs • operator interfaces • monitors, MOTION CONTROL
