Easily Interface Position Transducers to Control Systems
By Randy Frank | September 13, 2012
By adding a Synchronous Serial Interface (SSI) to its Micropulse Generation 7 linear position transducer line, Balluff simplifies interfacing to popular control systems. Manufacturers that use the SSI include Allen-Bradley, Delta Computer, Siemens, Bosch Rexroth, and others. The SSI-output products have features including:
  • Stroke lengths from 25 mm to 7620 mm
  • Pressure rated to 600 bar; ideal for use in hydraulic      cylinders
  • Update rates up to 5 kHz for improved dynamic      performance
  • User-configurable via PC/USB interface
Applications for the transducers include all types of automated machinery where a continuous, absolute position signal is required, such as plastic injection and blow molding, tire and rubber manufacturing, stamping presses, and die casting.
For more information on Balluff Micropulse transducers, click here.
Sensor Tips
Filed Under: Hydraulic equipment + components, Sensor Tips
Tagged With: balluff
