Ultra Motion introduce the Easy-DC Linear Actuator Controller. This unit provides a simple and rugged solution for DC linear actuator control. The controller can supply continuous motor current up to 20 amps with an operating voltage range of 7-42V DC (5.5-50V DC extended range). The operating temperature range is -40C to 125C, and the controller is sealed to IP65. The default device configuration provides extend/retract inputs, limit switch inputs, optional speed control, and output for a power-on or power-off brake.
The controller is protected from reverse polarity power input (up to -55V) and its signal and power lines are protected from over-voltage. Our shock-resistant solid-state control board is securely mounted within a precision-machined and mil-spec-anodized aluminum housing. This compact linear actuator controller is perfect for demanding applications in fields including aerospace, medical equipment, industrial automation, and scientific research. The Easy-DC Linear Actuator Controller complies with MIL-SPEC 704B for 28V aircraft power systems. Custom versions are available for meeting additional vibration, EMI, and environmental standards.
Ultra Motion
www.ultramotion.com
Filed Under: Actuators, Linear motion • slides, Motion control • motor controls
