The G10 family of Ultra-Compact I/O Modules with Connect & Done technology eliminates mounting requirements in many applications. The AS-Interface I/O module with IP68/69K protection is 40 mm x 27 mm x 22 mm and fits into any cable duct for quick, convenient sensor connections using the integrated M12 pigtails.
The robust single-piece housing uses a hinged cover design that simplifies connectivity, ensures reliable contact to the AS-Interface flat cable, and eliminates many additional mounting requirements. For applications requiring mounting, two integrated M4 screw holes are provided. Sensors are powered from the AS-Interface cable, and a continuous output current of up to 1 A can be supplied from AUX power.
Pepperl+Fuchs
www.pepperl-fuchs.us
Filed Under: I/O modules, Networks • connectivity • fieldbuses, Sensors (position + other)
