ebook: UtiliTrak® Compact Linear Guides
By Editor Design World | January 30, 2019
UtiliTrak® is an ideal choice for running two systems in parallel, where one slide uses DualVee® guide wheels and the other uses MadeWell® crowned rollers. Because precise parallelism is difficult to achieve, it is not uncommon for mounting surfaces to be slightly out of parallel. UtiliTrak’s design compensates for mounting errors, and does not require absolute parallelism for accurate operation. The DualVee guide wheel plate assembly and vee channel serves as the motion side, while the MadeWell crowned roller and open channel side allows for parallel misalignment.
Download this ebook from Bishop Wisecarver to learn more about UtiliTrak…
Filed Under: Tech Tips
Tech Tips: Crossed Roller Bearing Update
Linear Guides That Improve High-Precision Applications
Linear-Motion Solutions for the Design Engineer Tech Tips
IIoT Sensors and Systems with IO-LINK
