This portable anemometer provides fast, accurate readings with digital readability and the convenience of a remote probe.
The large LCD reads air velocity and temperature simultaneously and it can record minimum and maximum reading with recall. The CE compliant HHF42 also comes with a heavy duty carrying case. The HHF42 is an economical solution for any air flow application, such as, air conveyors, flow hoods, balancing, fans/motors/blowers, furnace velocities, refrigeration cases, paint spray booths and environmental testing.
Filed Under: Test + measurement • test equipment
